Введение
If the laptop is not showing any signs of turning on, there's a chance the battery is defective or loose. You can secure the battery in place and learn how to remove it by following this device tutorial.
Выберете то, что вам нужно
Insert an opening pick between the chassis and keyboard.
Gently slide the pick around the perimeter of the keyboard while prying until it releases completely.
Remove the keyboard.
Disconnect the cable connector from the motherboard.
Slide the cable out of the case.
Place the the computer bottom facing up. Unscrew the eleven Phillips #0 6 mm screws.
Remove the two 9 mm Phillips #0 screws that secure the battery.
Remove the battery from the device.
