Выберете то, что вам нужно
Orient the laptop so the top is laying flat on your work surface.
Remove ten 1.5mm Torx T5 screws from the back of the laptop.
Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
Remove the back cover.
Еще один человек закончил это руководство.
