Введение
If the keyboard has stopped working, or it's missing keys, follow the steps in this guide to replace it.
The battery for this device is not easily accessible and cannot be easily removed. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you drain the battery completely before you begin this replacement.
Выберете то, что вам нужно
Place the opening tool's head under any edge of the keyboard.
Pull upwards to unsnap the keyboard.
Use your fingers and the opening tool to pop the keyboard out of its place.
Push the keyboard connector latch upwards with the spudger.
The keyboard connector cable should slide right out.
3 участников успешно повторили данное руководство.
