Введение
Guide to safely and effectively replace the battery to the Lenovo IdeaPad 330-15AST.
Выберете то, что вам нужно
Remove the 7 mm Phillips screw from the back of the laptop which holds the optical drive in place.
Use opening picks or a plastic pry tool to remove the cover on all sides then lift.
Detach the battery pack connector from the motherboard using your fingers or an opening tool.
Почти готово!
Заключение
