Lenovo IdeaPad 330S-14IKB Fan Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad 330S-14IKB Fan Replacement, Fan: шаг 1, изображение 1 из 1
    • Place the laptop with its bottom facing up, so you can easily read the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 2, изображение 1 из 1
    • Remove the 10 screws from the bottom of the laptop.
    • Keep these screws in a safe place, such as a magnetic pad, to prevent them from getting lost.
    • (Silver, 5.8mm Phillips #0)
  3. Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 3, изображение 1 из 1
    • Slowly and carefully remove the back panel from the laptop.
    • Use wedges if necessary to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 4, изображение 1 из 1
    • Locate the fan in the top left corner of the laptop.
  5. Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 5, изображение 1 из 2 Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 5, изображение 2 из 2
    • Find the black panel in the top right and remove the three black screws.
    • Remove the black panel
    • Keep the black screws separate from the silver ones.
    • (Black, 5.83mm Philips #0)
  6. Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 6, изображение 1 из 1
    • Your fan will have one black screw connected to it on the left side. Remove this screw.
    • Keep the screw separate from the black screws in the previous step as it is a different size.
    • (Black, 3.47mm Phillips #0)
  7. Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 7, изображение 1 из 1
    • The fan is connected to a heat sink; leave the heat sink in place but remove the adhesive connecting the two pieces.
  8. Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 8, изображение 1 из 2 Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 8, изображение 2 из 2
    • Before removing the fan, locate a small set of yellow, red, blue, and black wires on the right side of the fan.
    • Gently remove them from the connector without pulling on the wires.
    • You can use a screwdriver or a similar tool to assist in this step.
  9. Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 9, изображение 1 из 2 Lenovo IdeaPad 330S-14IKB Fan Replacement: шаг 9, изображение 2 из 2
    • Disconnect the large black wire connected to the slot on the side of your fan.
    • Remove your fan.
Заключение
3 участников успешно повторили данное руководство.
sal
Участник с: 10/02/23
459 Репутация
Автор 2 руководств
Команда
Linn Benton Community College, Team 1-3, Karnes Fall 2023 Участник Linn Benton Community College, Team 1-3, Karnes Fall 2023
LBCC-KARNES-F23S1G3
5 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 15
За последние 30 дней: 25
За всё время: 157
