Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: шаг 1, изображение 1 из 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: шаг 1, изображение 2 из 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement, Back Cover/Midframe: шаг 1, изображение 3 из 3
    • With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
    • Wedge the opening tool until you start hearing the back cover popping off the body of the device.
    • Slide the opening tool down the length of the device.
    • Once it is about half way off, you can use your thumb to pull the rest of the back cover off.
  2. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: шаг 2, изображение 1 из 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: шаг 2, изображение 2 из 3 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: шаг 2, изображение 3 из 3
    • Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
    • With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
    • Do not force the frame off because you can break off the teeth securing the frame to the screen.
    • Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
    • The gray frame will still be connected to the device by a pair of wires from the motherboard to the speaker.
  3. Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: шаг 3, изображение 1 из 2 Lenovo IdeaPad A1-07 Back Cover/Midframe Replacement: шаг 3, изображение 2 из 2
    • The speaker in the grey frame is connected to the motherboard by the white plastic connector.
    • Disconnect the speaker by separating the two sides of the speaker connector.
Заключение
Madison Cranmer
Участник с: 04/10/17
370 Репутация
Автор 4 руководств
Команда
Eastern Washington University, Team S1-G4, Crane Spring 2017 Участник Eastern Washington University, Team S1-G4, Crane Spring 2017
EWU-CRANE-S17S1G4
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 424
