Введение
If your computer becomes unresponsive during use, then it is probably due to your circuit board.
Выберете то, что вам нужно
Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
Pop off the back panel using a plastic opening tool once all screws are removed.
Use the iFixit Opening tool to disconnect the battery from the circuit board.
When all screws are removed from the battery, carefully lift the battery up.
Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
Once fan and battery are removed, you are finally able to fully access the circuit board.
After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer.
After the screws are removed from the circuit board, you will have to remove these last screws to remove it completely.
