Введение
If the laptop begins to freeze up then it is a problem with the fan.
Выберете то, что вам нужно
Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
Pop off the back panel using a plastic opening tool once all screws are removed.
Use the iFixit Opening tool to disconnect the battery from the circuit board.
When all screws are removed from the battery, carefully lift the battery up.
Еще один человек закончил это руководство.
