Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
A motherboard replacement is an uncommon procedure, but can oftentimes be a necessary step in fixing your Lenovo IdeaPad Flex4-1130. If you are in need of new RAM or are experiencing trouble with your Lenovo IdeaPad Flex4-1130 and have ruled out other components, a motherboard replacement is an efficient way to refresh your Lenovo IdeaPad Flex4-1130.
Выберете то, что вам нужно
Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
Remove one last connector cable.
Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
