Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If you are experiencing a delay between touching the touchpad and actual movement of the mouse on screen or a complete lack of mouse movement, a touchpad replacement might be needed.
Выберете то, что вам нужно
Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
Remove one last connector cable.
Motherboard should now be completely disconnected and can be lifted off the cover to be replaced.
Lift up the black tab on the ZIF connector and pull the ribbon cable out.
