Введение
A Wi-Fi card replacement is a quick and simple task. If you are experiencing slow or intermittent internet connection a Wi-Fi card replacement might be in order.
Запчасти
No parts specified.
  1. Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Remove the connector attaching the battery to the motherboard.
    • Remove the connector attaching the battery to the motherboard.
  4. PC Laptop Batteries
    Batteries for all the top PC brands, backed by our Quality Guarantee.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  5. Remove the four 4mm screws on the battery.
    • Remove the four 4mm screws on the battery.
  6. Lift the battery with a spudger and remove.
    • Lift the battery with a spudger and remove.
  7. Remove one 5mm screw. Remove one 5mm screw.
    • Remove one 5mm screw.
  8. Remove the Wi-Fi card from the motherboard socket. Remove the Wi-Fi card from the motherboard socket.
    • Remove the Wi-Fi card from the motherboard socket.
Заключение
Adrian Miranda
Участник с: 15.02.2018
677 Репутация
Автор 5 руководств
Команда
USF Tampa, Team S17-G5, Boczar Spring 2018 Member of USF Tampa, Team S17-G5, Boczar Spring 2018
USFT-BOCZAR-S18S17G5
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 3
За 30 дней: 7
За всё время: 68
