Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: шаг 2, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: шаг 2, изображение 2 из 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Cmos battery: шаг 3, изображение 1 из 1
    • Using the JIS #0 screwdriver unscrew the three battery screws.
  4. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: шаг 4, изображение 1 из 1
    • Lift up the battery from the long, bottom edge.
    • Remove the battery from the laptop and place it nearby.
  5. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: шаг 5, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: шаг 5, изображение 2 из 2
    • Remove the red and black annotated cable, pulling white head out of black port as indicated.
  6. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: шаг 6, изображение 1 из 1
    • Ply the CMOS battery off with your finger.
    • The battery is attached to the computer by adhesive, but should come off by pulling with fingers; plying tool should not be necessary.
Заключение
2 участников успешно повторили данное руководство.
Elijah Ellis
Участник с: 11/08/18
616 Репутация
Автор 5 руководств
Команда
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 Участник UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G2
3 членов
Автор 5 руководств
Один комментарий
Does this procedure reset the BIOS?
Mark Webb - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 2,566
