Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: шаг 2, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: шаг 2, изображение 2 из 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Hard Drive: шаг 3, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement, Hard Drive: шаг 3, изображение 2 из 2
    • Remove the three 4 mm Phillips #0 screws holding the hard drive in place.
    • Note: A security sticker is normally affixed to the upper-right screw that helps hold the drive in the machine.
  4. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Remove the hard drive by pulling it out of its port (away from the hinges).
    • It's normal to feel a lot of resistance, especially if this is the first time the hard drive is being removed. Just ensure that you have removed all three screws.
  5. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: шаг 5, изображение 1 из 1
    • Remove the four 3 mm Phillips #0 screws located on opposite sides of the hard drive.
    • These screws hold the hard drive in the hard drive mounting bracket. All computers use a hard drive mounting bracket because the standard holes on hard drives are not in a convenient place for direct mounting. All laptop hard drives will fit in any laptop's mounting bracket but the brackets are specific to the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Remove the hard drive from the mounting bracket.
Заключение
17 участников успешно повторили данное руководство.
Heeral Patel
Участник с: 10/02/17
406 Репутация
1 руководство автора
Команда
USF Tampa, Team S1-G6, Thompson Fall 2017 Участник USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 членов
Автор 10 руководств
2 Комментариев
Thanks for posting! Any suggestions on the best means to transfer (mirror) the old to new drive?
Douglas Henningsen - Ответить
This guide comes up when I click on “keyboard replacement.” Is there a guide for keyboard replacement? A search does not find one.
Greg Worrel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 41
За всё время: 8,903
