Lenovo IdeaPad Flex 4-1470 Speaker Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Lower Case: шаг 1, изображение 1 из 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 2, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 2, изображение 2 из 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Battery: шаг 3, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Battery: шаг 3, изображение 2 из 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 4, изображение 1 из 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 5, изображение 1 из 1
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Speaker: шаг 6, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Speaker Replacement, Speaker: шаг 6, изображение 2 из 2
    • The speakers are not screwed or bolted in like any other components. They have two rubber grommets at each end which hold it in with friction.
    • Starting with the speaker on the right, use your fingers to lift both ends of the speaker off.
    • The grommets may fall off when removing the speaker. When reassembling make sure you place the grommets back into the notches on the speaker before trying to mount the speaker. The specific orientation and position doesn't matter
  7. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 7, изображение 1 из 1
    • In addition to the grommets, the speaker wire running to the motherboard is clipped down.
    • Remove speaker wire from the clips.
  8. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 8, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 8, изображение 2 из 2
    • Repeat the previous steps for the other speaker.
  9. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 9, изображение 1 из 1
    • Remove the wire shown using the plastic opening tool.
  10. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 10, изображение 1 из 2 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 10, изображение 2 из 2
    • Use the Plastic Opening tool to flip open the ribbon cable clip shown.
    • Pull gently on the ribbon cable to disconnect it from the motherboard.
  11. Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 11, изображение 1 из 3 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 11, изображение 2 из 3 Lenovo IdeaPad Flex 4-1470 Speaker Replacement: шаг 11, изображение 3 из 3
    • Now that both speaker wires are free, disconnect the speakers from motherboard using two plastic opening tools.
    • Keep in mind that the red and black wires lead to the left speaker and the blue and white wires lead to the right speakers.
Заключение
Еще один человек закончил это руководство.
Robert Cartwright
Участник с: 10/02/17
192 Репутация
1 руководство автора
Команда
USF Tampa, Team S1-G6, Thompson Fall 2017 Участник USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 9
За всё время: 810
