Введение
This guide will show you how to remove and replace the battery of your Lenovo IdeaPad Flex 5 14ARE05.
Выберете то, что вам нужно
Remove the five 8 mm screws using a T5 Torx Screwdriver.
Remove the four 5 mm screws using a T5 Torx Screwdriver.
Use a small suction cup to pull open the back case at the two hinge cutouts.
Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
Remove the four 5 mm Phillips #00 screws that secure the battery in place.
Rotate the device 90 degrees.
Gently lift up on the battery and use a spudger to disconnect the battery connector.
3 участников успешно повторили данное руководство.
