Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Use this guide to replace a faulty or failing battery in your Lenovo IdeaPad Flex 5-1470 laptop.
The battery is a piece of hardware that provides power to your computer. A failing battery can cause your laptop to shut down irregularly and/or die quickly even when it is fully charged. In some cases, your computer may not turn on at all if it is experiencing battery failure.
Before using this guide, make sure to review the troubleshooting page—this will allow you to review symptoms and conclude that the battery is the problem.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
  1. Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Use the plastic opening tool to lift up and remove the casing. Use the plastic opening tool to lift up and remove the casing.
    • Use the plastic opening tool to lift up and remove the casing.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
    • Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
  5. Gently unplug the multi-colored cable connecting the battery to the motherboard. Remove the battery from the laptop.
    • Gently unplug the multi-colored cable connecting the battery to the motherboard.
    • Remove the battery from the laptop.
Заключение
Еще один человек закончил это руководство.
Tori Nardoni
Участник с: 23.01.2020
253 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S2-G5, White Winter 2020 Участник Cal Poly, Team S2-G5, White Winter 2020
CPSU-WHITE-W20S2G5
4 членов
Автор 11 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 18
За последние 30 дней: 59
За всё время: 451
