Введение
This guide will walk you through the steps of removing the SSD card. The SSD card is essential to the Lenovo IdeaPad Flex 6-14IKB because it allows for the laptop to obtain storage and the memory of the device.
Выберете то, что вам нужно
Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
Remove the single 3.5 mm screw that secures the SSD card using a Phillips #00 screwdriver.
3 участников успешно повторили данное руководство.
