Введение
This guide will walk you through the steps of replacing the speakers in the Lenovo IdeaPad Flex 6-14IKB. The speakers are essential to this laptop because they allow the user to hear sound. This guide will come to good use if you notice audio problems that arise on your laptop.
Выберете то, что вам нужно
Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
Lift the right side speaker off of the pins that the speaker is resting on using an iFixit opening tool.
Unwind the red and black wire that connects the two speakers from the plastic clips that secure it.
Lift the left side speaker off of the pins that the speaker is resting on using an iFixit opening tool.
Еще один человек закончил это руководство.
