Lenovo IdeaPad G50-45 Keyboard Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: шаг 1, изображение 1 из 2 Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: шаг 1, изображение 2 из 2
    • Slide the two locking tabs away from each other to unlock the battery.
    • Remove the battery from the laptop once it is unlocked to prevent any electrical damage.
  2. Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 2, изображение 1 из 1
    • Locate the three M2x6 screws on the bottom of the laptop base.
    • Use the #2 Phillips screwdriver to loosen and remove each screw.
  3. Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 3, изображение 1 из 1
    • Slide the cover off and remove from the base.
  4. Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 4, изображение 1 из 2 Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 4, изображение 2 из 2
    • Locate the three M2x6 screws that secure the keyboard in place.
    • The screws are labeled with a keyboard emblem.
    • Loosen and unscrew the three M2x6 screws with the #2 Phillips screwdriver.
  5. Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 5, изображение 1 из 1
    • Turn the laptop right side up once the screws that secure the keyboard to the base have been removed.
    • Pry around the keyboard to loosen it apart from the laptop with the spudger, beginning at the top left corner.
    • You will hear audible "clicks" as the keyboard is separated from the base.
  6. Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 6, изображение 1 из 1
    • Lift the top of the keyboard up and forward once the top of the keyboard has been released.
    • Be VERY careful to remove the keyboard only a few inches to not damage the connecting ribbon cable.
  7. Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 7, изображение 1 из 1
    • Lift the black locking tab with the spudger to release the connecting ribbon cable.
    • Disconnect the ribbon cable by pulling it straight out.
    • Be careful to not damage the ribbon cable with the spudger.
  8. Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 8, изображение 1 из 1
    • Remove the keyboard after the ribbon cable is disconnected.
  9. Lenovo IdeaPad G50-45 Keyboard Replacement: шаг 9, изображение 1 из 1
    • When installing the replacement keyboard, first insert the bottom of the keyboard into the three slots of the base.
    • Complete the keyboard installation by pressing down on the top of the keyboard until you hear the clips snap back into place.
Заключение
8 участников успешно повторили данное руководство.
Saulo Gomes
Участник с: 10/26/15
601 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Участник UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 членов
Автор 5 руководств
Один комментарий
I had an issue with the numbers at the top of alphabets. Some keys didn't work. I followed the instructions above to clean up the keyboard and hoped that would work. I could successfully remove and reassemble the keyboard but that didn't solve it.
I read it somewhere that this could be a hardware issue and the whole keyboard needs to changed. Is it really the case? Can't few keys be changed or fixed somehow?
Thank you.
Pritam Patil - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 12,630
