Выберете то, что вам нужно
Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
Gently lift the keyboard off the chassis.
Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
Еще один человек закончил это руководство.
Один комментарий
WARNING!!!!!!
These steps do not include removing the three screws that secure the keyboard to the bottom of the latop!!! They are marked with tiny keyboard icons. One is under the bottom panel, so that has to be removed first.
