Выберете то, что вам нужно
To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
Now push the right clip to the right and hold it while using your other hand to pull the battery out.
Push hard drive away from the center of the chassis.
Lift the hard drive out of the chassis using the tab located on the drive.
Now push the little clips out away from the memory to unlock the memory.
Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
Gently lift the keyboard off the chassis.
Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
Flip laptop over.
3 участников успешно повторили данное руководство.
2 Комментариев
You cannot must pull up on the keyboard. There are three screws on the bottom of the case that have to be removed first!!
My laptop open hoi no please tell me why open hoi na please vaia
