Запчасти
Никакие детали не требуются.
  1. To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left. To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Now push the right clip to the right and hold it while using your other hand to pull the battery out. Now push the right clip to the right and hold it while using your other hand to pull the battery out.
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Remove the two screws highlighted.
    • Remove the two screws highlighted.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. This is the back of the laptop with the cover removed.
    • This is the back of the laptop with the cover removed.
  6. Remove the white and black wires. Remove the white and black wires.
    • Remove the white and black wires.
  7. Next, unscrew the wifi card Next, unscrew the wifi card
    • Next, unscrew the wifi card
  8. Pull out the wifi card.
    • Pull out the wifi card.
Заключение
Christopher
Участник с: 08.04.2014
666 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 8-7, Regan Spring 2014 Member of Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 529
