Введение
It is important to ensure that the computer is unplugged from any charging cable while working with it. Removing the battery should be the first step in removing or replacing any other part of your computer. This helps prevent injuries to yourself or to your device. There is one exception for the Lenovo IdeaPad P400 Touch: to remove the battery, you will first need to remove the keyboard by following the prerequisite guide.
Выберете то, что вам нужно
Remove the two 14mm Phillips #1 screws that attach the keyboard to the underside of the laptop.
Using your hands, lift the top corner of the keyboard, and keep lifting until the keyboard pops out. You will hear clicks as you do this.
Lift the top of the keyboard and flip the keyboard face down so that you can access the connectors underneath it.
Using your fingers, unplug the large connector that connects the keyboard to the center of the laptop by sliding the end of the strip out of the socket.
Using your fingers, unplug the second, smaller connector, located at the lower left hand side of the keyboard by sliding the strip out of the socket.
Flip the laptop so that the bottom faces up.
You will first need to remove three 7mm Phillips #1 screws from the bottom of the laptop.
Remove the 7mm Phillips #1 screw beneath where the foot was. Do this for both sides.
Flip the laptop over and open it.
Remove the 3mm Phillips #1 screw holding the disc drive in place.
Remove the disc drive by sliding it out.
Close the laptop lid and flip it over.
Remove three 3mm Phillips #1 screws from beneath where the disc drive was located.
Using a plastic spudger, pry open the laptop case starting near the disc drive.
Continue prying open the case by using the spudger to open it in new areas.
Once there is enough space to allow you to grip the case, use your hands to finish removing it.
Using your fingers, unplug the battery from the laptop by taking the plug out of its socket.
Using your hand, remove the battery from the laptop by lifting one side and then pulling it out of its slot.
11 человек успешно провели ремонт по этому руководству.
5 Комментариев
Thank you!!
Your advice and pictures really helped!
Really useful guide. Thank you!!
