Введение
This task will require you to disassemble the laptop and work with small connectors and wires. It is important to make sure that you follow the steps to remove the battery and keep the laptop unplugged while working on it. This will help avoid damaging the electronics.
Выберете то, что вам нужно
Remove the two 14mm Phillips #1 screws that attach the keyboard to the underside of the laptop.
Using your hands, lift the top corner of the keyboard, and keep lifting until the keyboard pops out. You will hear clicks as you do this.
Lift the top of the keyboard and flip the keyboard face down so that you can access the connectors underneath it.
Using your fingers, unplug the large connector that connects the keyboard to the center of the laptop by sliding the end of the strip out of the socket.
Using your fingers, unplug the second, smaller connector, located at the lower left hand side of the keyboard by sliding the strip out of the socket.
Flip the laptop so that the bottom faces up.
You will first need to remove three 7mm Phillips #1 screws from the bottom of the laptop.
Remove the 7mm Phillips #1 screw beneath where the foot was. Do this for both sides.
Flip the laptop over and open it.
Remove the 3mm Phillips #1 screw holding the disc drive in place.
Remove the disc drive by sliding it out.
Close the laptop lid and flip it over.
Remove three 3mm Phillips #1 screws from beneath where the disc drive was located.
Using a plastic spudger, pry open the laptop case starting near the disc drive.
Continue prying open the case by using the spudger to open it in new areas.
Once there is enough space to allow you to grip the case, use your hands to finish removing it.
Using your fingers, unplug the battery from the laptop by taking the plug out of its socket.
Using your hand, remove the battery from the laptop by lifting one side and then pulling it out of its slot.
Remove the two 8mm Phillips #1 screws holding the right speaker in place.
Remove the right speaker.
Gently pull the blue and white wire out of its plastic clips.
Remove the left speaker.
Gently pull the red and black wire out of its plastic clips.
Using your fingers, remove the speaker connector from its port by sliding it out.
