Введение
This guide will provide instructions to remove the bottom case of the laptop. This is the first step in replacing most of the parts in this computer.
Запчасти
Никакие детали не требуются.
  1. Turn off laptop before beginning.
    • Turn off laptop before beginning.
    • Remove the five 5.0 mm Phillips #0 screws marked in this picture.
    There are four screws under the rubber caps, as well as more under the keyboard that must come out before the lower case can be removed.
    Adam - Ответить
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Use the spudger to separate the bottom panel from the laptop case. It is recommended that you start from a corner and work your way around the panel. Be careful not to bend or break the bottom panel.
    • Use the spudger to separate the bottom panel from the laptop case.
    • It is recommended that you start from a corner and work your way around the panel.
    • Be careful not to bend or break the bottom panel.
  4. Lift up the right side of the case as shown, and slide it to the left to detach the case. The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it. To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
    • Lift up the right side of the case as shown, and slide it to the left to detach the case.
    • The disk drive will remain attached to the bottom panel. Sliding the panel to the left disconnects it.
    • To avoid damaging the disk drive connector, avoid lifting the right side of the panel too far up.
Заключение
Joel Hottman
Участник с: 28.09.2018
280 Репутация
Автор 3 руководств
Команда
Один комментарий
awful guide, you need to remove the screws underneath the pads on the bottom plate, as well as remove the screws underneath the keyboard that lets you take the disc drive out, then take out the disc drive revealing more screws needed to take out in order to take off the bottom plate.
Ward McKinley - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 5
За 30 дней: 14
За всё время: 103
