Введение
This guide will walk you through replacing the space bar. The space bar in particular works with hinges unlike some of the other keys.
Выберете то, что вам нужно
Pull back the key to remove and separate the key from the metal bars underneath.
Ensure the bars are in correctly before continuing. The end of the top bar should be in the hooks and the end of the bottom bar should go through the loops.
Почти готово!
Финишная черта
