Введение
If you're experiencing problems connecting to the internet there may be issues with your wireless card. The replacement requires the flat end of a spudger and a Phillips J0 head screwdriver. The cost of a wireless card ranges between $7 to $20.
Выберете то, что вам нужно
The tools needed are the blunt edge of the spudger and a Phillips J0 head screwdriver.
Turn the laptop over to begin.
Remove the two 40 mm screws with a Phillips J0 head screwdriver.
Using the blunt end of the spudger, wedge the spudger beneath the connector and pull straight up to remove the white wire. Repeat to remove the black connector.
Remove the two 40 mm screws using a Phillips J0 head screwdriver.
Lift and remove the WiFi card.
Еще один человек закончил это руководство.
