Введение
If you are experiencing longer than average start-up times or unexpected display issues such as freezing, it may be time to replace your motherboard.
Use this guide to learn how to safely remove the motherboard of a Lenovo IdeaPad S210 Touch. Knowing how to remove the motherboard is also necessary should you need to access some of the other internal hardware like the storage drive and fans.
Before using this guide, make sure that your computer is completely powered off and that all cables are unplugged. Be careful when using a screwdriver near the motherboard, as any contact could result in damage. If you need to set the motherboard down, remember to use a padded surface to protect sensitive components.
Выберете то, что вам нужно
Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
Using a Phillips #0 screwdriver, remove four 2.5mm screws, two per side, to release the hard drive from its mounting bracket. These screws are directly next to each mounting screw you removed previously.
If any tape is present, remove all tape from the area within the red area.
Using a #0 Phillips screwdriver, unscrew the four 3mm captive screws securing the copper tube onto the motherboard.
Remove the tape connecting the copper tubing to the cooling fan.
Lift and remove the heat sink assembly.
Using a #0 Phillips screwdriver, remove the three 3mm screws around the perimeter of the fan.
Remove the wiring from the motherboard by gently pulling the wire connector at the base of the wires.
Once the wires are removed, the cooling fan assembly is disconnected. You may now remove the cooling fan.
Remove four cables connected to motherboard by pulling gently on connector at base of cables.
Use a spudger to lift the connector lock to the small ribbon cable attached near where the cooling fan was located.
After unlocking the connector, gently pull the removal tab on the ribbon cable to remove completely.
Using a #0 Phillips screwdriver, remove the seven 3mm screws securing the motherboard to the chassis.
Using a spudger, remove the smaller of the two ribbon cables by lifting on the black connector.
Once connector is lifted, gently pull on the ribbon cable to remove it.
Remove the second (and last) ribbon cable from the motherboard by gently pulling on the blue pull tab.
Lift and remove motherboard from laptop chassis.
