Выберете то, что вам нужно
Power off the laptop and place it face-down on a non-scratching surface.
Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
Slide a plastic opening tool underneath the back case near the screen hinges.
Gently pry up on either side of the case.
Using your thumbs, gently pull the two metal prongs that secure the RAM outwards.
Remove the RAM from the laptop.
Еще один человек закончил это руководство.
