Введение
If you need more storage space, or a boost in speed, this guide will help you to replace the RAM in your IdeaPad.
Выберете то, что вам нужно
Flip the device over so the bottom panel is facing up.
Remove the rubber feet by pinching and pulling in an upward motion.
Place the plastic opening tool between the bottom panel and device.
Pry around the device's outer edge until the bottom panel is no longer attached.
Lift the bottom panel up and away from device.
4 участников успешно повторили данное руководство.
