Введение
The network adapter is attached to the motherboard on this device. The back panel of the device must be removed to reach the adapter.
Выберете то, что вам нужно
Remove all of the screws on the back panel with a Phillips #000 screwdriver.
Turn over the device and remove the two screws on the outside of the hinges.
Use a pry tool or iFixIt Opening tool to separate the back panel from the device.
Lift the back panel straight up to remove.
Remove the two screws attaching the network adapter to the motherboard.
Remove the network adapter by sliding it down out of its connector.
