Введение
This guide will help you replace the RAM and fix issues like, your laptop running slowly or commonly used apps and functions showing error messages.
Выберете то, что вам нужно
Slide the left battery lock to the unlock position and release.
Slide the right battery lock to the unlock positon and hold it in place.
While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
Lift the bottom cover off using a metal spudger and set it aside.
Simultaneously pull apart both clips that are holding the RAM module down.
When the RAM module is released carefully pull it out.
