Введение
This guide provides instructions on how to replace the daughterboard in the Lenovo IdeaPad Y580-2099 laptop. Removing this part does not require any specialized training or experience as long as the steps are followed closely.
Выберете то, что вам нужно
Slide out both locks for the battery, located on the back of the device.
Unscrew the 2 screws on the bottom of the device.
Slide the back panel out.
Flip the laptop over and open up.
Then pry up the whole keyboard using the spudger.
Use a Phillips #0 screwdriver to remove the 16 screws highlighted. There are 12 M2.5 x 8 mm long screws, and 4 M2 x 2 mm long screws.
Use a Phillips #0 screwdriver to remove the 10 mm screw (highlighted in orange) that secures the disc drive.
Quickly survey and make sure all screws on the back panel are removed from the device.
Use a Phillips #0 screwdriver to remove the three M2 x 3 mm long screws circled in red.
Now that the top plate is removed, locate the daughter board. (Highlighted in Red).
Use a plastic spudger or precision tweezers to carefully unhook the daughterboard cables.
Use a Phillips #0 screwdriver to remove the two M2.5 x 3 mm long screws that secure the daughterboard.
Check and make sure all screws and cable wires are detached before attempting to remove the daughterboard.
Carefully remove the daughterboard.
