Введение
This guide provides instructions on how to replace the fan and heat sink assembly on the Lenovo IdeaPad Y580-2099 laptop. The fan and heat sink are a combined assembly which can not be separated from each other.
Выберете то, что вам нужно
Slide out both locks for the battery, located on the back of the device.
Unscrew the 2 screws on the bottom of the device.
Slide the back panel out.
Flip the laptop over and open up.
Then pry up the whole keyboard using the spudger.
Flip laptop back over and unscrew the disc drive screw.
Remove the disc drive.
Unscrew all of the screws on the back of the device.
Flip the device over.
Unplug the two wires, as shown in the images.
Lift up on the keyboard bezel.
Unscrew the screws on the motherboard.
Disconnect the three connectors the two black and one white.
