Введение
In order to proceed with this guide, you should know that the laptop must not be plugged in for safety reasons. The laptop should also be powered off and the battery drained. Once completed, safely dispose of the old keyboard.
Выберете то, что вам нужно
Place the laptop face down with the battery slot facing away from you.
Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
Remove the back panel from the device.
Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
Now orient the laptop in the standard position and take off the keyboard.
2 участников успешно повторили данное руководство.
