Lenovo IdeaTab S2109A-F Battery Replacement
Выберете то, что вам нужно
  1. Lenovo IdeaTab S2109A-F Battery Replacement, Battery: шаг 1, изображение 1 из 2 Lenovo IdeaTab S2109A-F Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Battery Replacement: шаг 2, изображение 1 из 2 Lenovo IdeaTab S2109A-F Battery Replacement: шаг 2, изображение 2 из 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Battery Replacement: шаг 3, изображение 1 из 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
Заключение
Еще один человек закончил это руководство.
Caelen
Участник с: 01/16/15
228 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 17-3, Watkins Winter 2015 Участник USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 членов
Автор 10 руководств
2 Комментариев
Folks this is not easy! The first thing that happened, my screen broke. Then it took about thirty minutes to finally get the back off and the on-off swithch was damaged. Take it to a shop and let them do the damage, then its up to them to pay for it or replace it. I’m now out a s2109 Lenovo tablet because the instructions said easy. Maybe his was. This one sure as heck was not!!
jangoodman - Ответить
Theres some screws missing from the directions, under the speakers and in a hole along one side. Tiny torx on the side.
Devin Holland - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 1,533
