Введение
The following guide details the necessary steps that you have to follow in order to replace the vibration motor for the Lenovo IdeaTab S6000.
Запчасти
Никакие детали не требуются.
  1. Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
  2. Remove the screws from both of the spots that were covered.
    • Remove the screws from both of the spots that were covered.
  3. DO NOT USE A METAL TOOL FOR THIS.
    • DO NOT USE A METAL TOOL FOR THIS.
    • Go all around the casing, prying the screen away from the backing with the spudger.
    • It will make a popping sound each time one of the lock tabs is disconnected.
    • Take your time as you move all around the device when prying the backing off.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Pull off the plastic that is covering the battery cable.
    • Pull off the plastic that is covering the battery cable.
  6. Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it. Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
    • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
  7. Remove the battery by grabbing the tab shown and pulling up.
    • Remove the battery by grabbing the tab shown and pulling up.
    • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
  8. Use the spudger to pry up the vibration motor.
    • Use the spudger to pry up the vibration motor.
Заключение
Gabriel Delgado
Участник с: 22.09.2014
246 Репутация
1 Guide authored
Команда
USF Tampa, Team 10-4, Brown Fall 2014 Member of USF Tampa, Team 10-4, Brown Fall 2014
USFT-BROWN-F14S10G4
4 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 1
За 30 дней: 4
За всё время: 849
