Введение
This guide will instruct you on how to remove and replace the speakers of Lenovo Ideapad 110S-11IBR.
Выберете то, что вам нужно
Separate the back lid from the laptop using a plastic opening tool.
Lift the back lid off of the device.
Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
Remove the two pieces of tape that are holding the battery down.
Use your fingers to gently remove the speaker connector from its socket.
