Введение
This guide will assist you in removing and replacing the touchpad for the Lenovo Ideapad 120s-14IAP. The touch pad is a common issue with this model, and will fix problems with a mouse pointer that will not move or becomes jumpy on the screen.
Выберете то, что вам нужно
Orient the laptop so the top is laying flat on your work surface.
Remove ten 1.5mm Torx T5 screws from the back of the laptop.
Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
Remove the back cover.
Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
Pull on the plastic film to remove the display connection cable.
Remove the wireless card by disconnecting the two antenna cables and removing the 2.5 mm Phillips #0 screw.
Remove seven 2.5 mm Phillips #0 screws from the motherboard.
Slide the motherboard out of the laptop chassis.
Remove five 2.5 mm Phillips #0 screws from around the battery.
Lift the battery out of the laptop.
Remove four 2.0 mm Phillips #0 screws from the speaker assemblies.
The speakers can now be lifted up.
Remove six 2.5 mm Phillips #0 screws from the battery bracket.
Lift the battery bracket out of the laptop.
Remove six 5.0 mm Phillips #0 screws from the screen hinges.
You can now lift the bottom cover and separate each half of the laptop.
Remove three 2.0 mm Phillips #0 screws from the touchpad retention bracket.
The touchpad now slides up and can be removed.
Еще один человек закончил это руководство.
