Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide will show you how to disassemble the back panel for the device.
This guide is also a prerequisite guide for other hardware part replacement.
Запчасти
Детали не указаны.
  1. Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Carefully remove the optical drive bracket by pulling the bezel away from the laptop. Carefully remove the optical drive bracket by pulling the bezel away from the laptop. Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop. Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  5. Use an opening tool to pry out the  back cover. Use an opening tool to pry out the  back cover. Use an opening tool to pry out the  back cover.
    • Use an opening tool to pry out the back cover.
  6. Remove the back panel by pulling it up and away from the laptop. Remove the back panel by pulling it up and away from the laptop. Remove the back panel by pulling it up and away from the laptop.
    • Remove the back panel by pulling it up and away from the laptop.
Заключение
Anurag Deb
Участник с: 31.10.2018
690 Репутация
Автор 3 руководств
Команда
Purdue University Northwest, Team S1-G5, Hingst Fall 2018 Участник Purdue University Northwest, Team S1-G5, Hingst Fall 2018
PNW-HINGST-F18S1G5
4 членов
Автор 13 руководств
Один комментарий
How Is solved Twisted screw and broken inside the frame
For laptop ip520
mohsen JUVE - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 54
За последние 30 дней: 195
За всё время: 2,638
