Введение
This guide will show you how to disassemble the back panel for the device.
This guide is also a prerequisite guide for other hardware part replacement.
Выберете то, что вам нужно
Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
3 участников успешно повторили данное руководство.
Один комментарий
How Is solved Twisted screw and broken inside the frame
For laptop ip520
