Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to safely remove the battery from your Lenovo Ideapad.
For your safety, drain your Lenovo Ideapad's battery before you begin this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
  1. Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Carefully remove the optical drive bracket by pulling the bezel away from the laptop. Carefully remove the optical drive bracket by pulling the bezel away from the laptop. Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop. Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Use an opening tool to pry out the  back cover. Use an opening tool to pry out the  back cover. Use an opening tool to pry out the  back cover.
    • Use an opening tool to pry out the back cover.
  6. Remove the back panel by pulling it up and away from the laptop. Remove the back panel by pulling it up and away from the laptop. Remove the back panel by pulling it up and away from the laptop.
    • Remove the back panel by pulling it up and away from the laptop.
  7. Remove the four 6mm screws using the Phillips #1 screwdriver.
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  8. Disconnect the battery connector by pulling toward the battery parallel to the motherboard. Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  9. Remove the battery.
    • Remove the battery.
Заключение
3 участников успешно повторили данное руководство.
Anurag Deb
Участник с: 31.10.2018
690 Репутация
Автор 3 руководств
Команда
Purdue University Northwest, Team S1-G5, Hingst Fall 2018 Участник Purdue University Northwest, Team S1-G5, Hingst Fall 2018
PNW-HINGST-F18S1G5
4 членов
Автор 13 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 20
За последние 7 дней: 195
За последние 30 дней: 868
За всё время: 10,520
