Введение
Use this guide to safely remove the battery from your Lenovo Ideapad.
For your safety, drain your Lenovo Ideapad's battery before you begin this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
Выберете то, что вам нужно
Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
25 участников успешно повторили данное руководство.
4 Комментариев
Votre explication est très bien détaillée et très explicite. Merci beaucoup vous m'avez vraiment aidé.
I can't get past the first step...pulling out the optical card. The rest I think I can do because I have done things like this before. I unscrewed the screw bu can't pull it out.
Unclip the tiny clips from where you removed the optical card. The back will come off
