Введение
If you are experiencing troubles with your fan and it needs to be replaced you can locate it inside the laptop.
Выберете то, что вам нужно
Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
Lift the fan slightly and straight upward and unwind the black and grey wires from the fan.
Identify the red, black, yellow, and brown wire coming from the back of the fan connecting to the motherboard with a white connector piece.
Slowly pull and wiggle the white connector piece until it comes loose from the laptop.
Еще один человек закончил это руководство.
