Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will show you how to remove and replace the hard drive for the device.
Before you start replacing the hard drive, make sure to turn the device off, remove the battery and disconnect the laptop from any power source.
  1. Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Carefully remove the optical drive bracket by pulling the bezel away from the laptop. Carefully remove the optical drive bracket by pulling the bezel away from the laptop. Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop. Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Use an opening tool to pry out the  back cover. Use an opening tool to pry out the  back cover. Use an opening tool to pry out the  back cover.
    • Use an opening tool to pry out the back cover.
  5. Remove the back panel by pulling it up and away from the laptop. Remove the back panel by pulling it up and away from the laptop. Remove the back panel by pulling it up and away from the laptop.
    • Remove the back panel by pulling it up and away from the laptop.
  6. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode. Gently lift up the hard disk from the left.
    • Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Gently lift up the hard disk from the left.
  7. Do not lift hard drive straight up as it risks  breaking the connection port. Carefully pull the hard drive away and out of the connection port. Carefully pull the hard drive away and out of the connection port.
    • Do not lift hard drive straight up as it risks breaking the connection port.
    • Carefully pull the hard drive away and out of the connection port.
  8. Detach the bracket from the hard drive by pulling the bracket edges apart. Detach the bracket from the hard drive by pulling the bracket edges apart. Detach the bracket from the hard drive by pulling the bracket edges apart.
    • Detach the bracket from the hard drive by pulling the bracket edges apart.
Заключение
17 участников успешно повторили данное руководство.
Anurag Deb
Участник с: 31.10.2018
721 Репутация
Автор 3 руководств
Команда
Purdue University Northwest, Team S1-G5, Hingst Fall 2018 Участник Purdue University Northwest, Team S1-G5, Hingst Fall 2018
PNW-HINGST-F18S1G5
4 членов
Автор 17 руководств
Комментариев: 3
What is the maximum thickness of the replacement Hard Drive/SSD.
Drew Howden - Ответить
It takes a standard 2.5” laptop HDD/SSD. They do not vary in thickness.
TheSolderSnake -
@TheSolderSnake You might want to use google to see the variation in 2.5” laptop drive thickness before making such a confident statement. ;)
Ben - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 22
За последние 7 дней: 96
За последние 30 дней: 456
За всё время: 11,071
