Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show you how to remove and replace the hard drive for the device.
Before you start replacing the hard drive, make sure to turn the device off, remove the battery and disconnect the laptop from any power source.
Выберете то, что вам нужно
Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
25 участников успешно повторили данное руководство.
4 Комментариев
What is the maximum thickness of the replacement Hard Drive/SSD.
It takes a standard 2.5” laptop HDD/SSD. They do not vary in thickness.
This is gonna be fun! lol. I’ll be doing this in 5-15 minutes. Wish me luck!!!
