Выберете то, что вам нужно
Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
Lay both sides of the laptop next to each other.
Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
Gently lift the fan assembly out of the laptop.
Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
Еще один человек закончил это руководство.
Один комментарий
Very helpful instructions. However, Step 6 indicates that you should remove 5 screws, but really you only need the 2 on the left that are actually connecting the fan to the system board, the rest are unnecessary. In fact, the machine I replaced this on only had the one screw in the top-left.
