Введение
This guide is meant to detail the location and disassembly of the fan unit on the underside of the Lenovo Ideapad 330-15ARR.
Выберете то, что вам нужно
Pry all edges off of the laptop with the opening tool until the lower case releases.
Remove the lower case.
Unscrew all three captive screws attaching the heat sink to the motherboard with a Phillips #0 screwdriver.
Take the wires in your hand, and firmly but gently pull it out of its port.
Lift the fan assembly out of the device.
