Введение
By the end of this guide, you will be able to remove the back panel from the laptop.
Выберете то, что вам нужно
Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
Using a plastic opening tool, make your way around the edge of the laptop.
There is a visible line between the bottom shell of the laptop and the laptop body itself.
Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
3 участников успешно повторили данное руководство.
