Введение
Is the back panel to your device cracked or broken? Consider using this guide to replace the back panel of your laptop.
Выберете то, что вам нужно
Remove the nine 6 mm screws using a T5 Torx Screwdriver.
Remove the two 10 mm screws using a T5 Torx Screwdriver.
Use a plastic opening tool to carefully pry off the back cover.
Remove the back cover.
Почти готово!
Финишная черта
